- wny_pat1Explorer II
You can buy these at: http://www.blackstone-labs.com/vacuum-pump.php. You will probably need longer tubing. It is 1/4" refrigerator tubing which you can get at most hardware store. - hzjcm8Explorer
docj wrote:
hzjcm8 wrote:
If anyone thinks there are other Good Sam Club forums that should be getting in on these Allison related posts, please invite them to drop in and ask their questions. I'm here to help where I can!!!
There is a very active forum run by the Escapees Club; I'm pretty sure you would have some interested folks there if you haven't already posted there. Escapees Club Forum
Docj,
I joined the Escapees Club forum and it's going well. Lots of good folks there too. - hzjcm8Explorer
stardalo wrote:
They sell a pump and tube you stick down the dipstick hole and pump out a small sample. I believe testing your tranny oil can also be used to extend your filter change intervals.
Steve,
You are correct (as usual). To get a transmission sample they'll need a hand operated vacuum pump and tubing to suck the fluid out of the sump through the fill (dipstick) tube.
Also, they'll need an Oil Analysis Kit that includes "Particle Count" and "ISO Cleanliness Code" to extend filter change intervals since this will give you information on the number of particles and teh sizes of particles that are in the system. - hzjcm8Explorer
racerchaser wrote:
I have a 3000 series transmission with a 4 inch sump filled with TranSynd. When I have the filters changed this summer I plan on using the fluid analysis. Since the filter change results in the loss of 10 quarts and the transmission holds 29 quarts I am replacing 1/3 of the fluid. Should the oil for the analysis be taken before or after the filters are changed and the new fluid added?
Racerchaser,
Purchase an Advanced Oil Analysis Kit and take a sample first, before you do anything else. Send it in right away for analysis and wait for the results. Then, if the fluid shows to be good, you can catch it in a "clean" bucket (and I do mean very clean) and put it right back in again after you change the filters. There's no need to top it off and throw out good fluid. Be sure to check the level at operating temperature after you've finished installing the new filters and you'll be good to go.
How's that for a "good" answer !!!! - stardaloExplorerThey sell a pump and tube you stick down the dipstick hole and pump out a small sample. I believe testing your tranny oil can also be used to extend your filter change intervals.
- Gadget_Guy1ExplorerWhat is the best way to get a sample of oil for analysis?
- racerchaserExplorerI have a 3000 series transmission with a 4 inch sump filled with TranSynd. When I have the filters changed this summer I plan on using the fluid analysis. Since the filter change results in the loss of 10 quarts and the transmission holds 29 quarts I am replacing 1/3 of the fluid. Should the oil for the analysis be taken before or after the filters are changed and the new fluid added?
- wolfe10Explorer
hzjcm8 wrote:
Wolfe10,
I posted the answer on the Foretravel Motorhome forum.
Thanks, Tom. Saw it right away. Your knowledge is much appreciated. - hzjcm8Explorer
wolfe10 wrote:
Tom,
This question was posted on the Foretravel Motorhome technical website. Your insight would be appreciated.
Brett
http://www.foreforums.com/index.php?topic=12914.msg69111;topicseen#new:
Use of SAE 15W40 motor oil in Allison HT746
« on: Today at 03:49:28 PM »
I just got some quotes on 34 quarts of Dexron III ATF for a transmission fluid change. I didn't like what I heard. I looked up what Allsion specs and it appears if I read it correctly that I can use SAE 15W40 motor oil instead of ATF at 1/4 of the cost. Has anyone done this successfully? Do you have any comments?
http://www.allisontransmission.com/documents/product/13-TR-90,%20Rev%20E.pdf
Re: This SIL replaces 13-TR-90, Rev. D. 13-TR-90, Rev. E
Please discard your copy of 13-TR-90, Rev. D. March, 2001
This SIL includes information about Allison Product Code(s):
oil recommendations, oil specifications and Page 1 of 4
Allison/Castrol TranSynd™ 1.
The guy is coming tomorrow to do the oil change so a quick answer would be appreciated.
Wolfe10,
I posted the answer on the Foretravel Motorhome forum. - docjExplorer
