From Winnebago Ind. 2012 Sunova manual.
Auto Level Remote Switches:
In addition to the Leveling System Control
Panel, there are two additional remote switches
for your leveling convenience.
These switches allow you to extend or retract
your jacks and observe them at the same time. It
also allows you to stop them suddenly, if needed,
without having to climb in and out of the coach.
The Auto Level Remote switches are located
just inside the entrance door and in the exterior
service center.
HOUSE/COACH BATTERY
DISCONNECT SWITCH
(COACH BATT)
The House/Coach Battery Disconnect switch
lets you disconnect the house batteries from the
12-volt system of your coach during storage
periods to avoid battery drain by electrical items
that are hooked directly to the house batteries,
such as clock displays and radio memories, etc.
Always leave this switch ON while using the
coach.
NOTE: Some electronic displays and memory
functions may need to be reset after
power has been reconnected.
