1963jarhead's avatar
1963jarhead
leveler down lite came on
I was driving yesterday after dumping and my leveling jack down light came on. 2003 Winnebago sightseer Class A.I cycled the levelers and the light went out, Anyone ever have this problem? Thanks
  • Winne usually had HWH your year. IF you have the NON automatic touch pad(300 series), then what you experienced is normal. The operating instructions for the 300 series requires you to ALWAYS push the store button every time you start the engine to travel. If you have this model HWH, respond and I will explain why. Doug
  • If Power gear jacks probably just low fluid. The fluid floats a switch that turns off the alarm. When you retract the jacks the fluid returns to the reservoir and floats the switch if there is enough fluid. Find the reservoir and check the fluid level. usually just needs a couple squirts of Dexron III will do the job
