btcruzer's avatar
btcruzer
leveler landing pad hits leaf spring
MH is a Fleetwood on an F-53 Ford chassis. The front leveler cylinders are mounted in such a way that the landing pad is slightly (maybe an inch) under the leaf spring. At times, usually at slow speed and in rough parking areas, the MH will sway to the right in such a way that the leveler pad will rise and rub on the bottom of the leaf spring. I've verified this by seeing wear marks on both the pad and spring. First thought was to cut off a piece of the pad. A lot of work in an uncomfortable place. Next Idea was to unbolt and place a spacer between the frame and the leveler. Investigation revealed the possibility that the LF tire COULD then hit the pad if turned sharply left during a bump/sway. Easiest and maybe the best remedy might be to unbolt leveler and mount in different mounting holes. It appears now to be mounted in the highest position. Has anyone encountered this situation? how was it resolved?
