Trackrig wrote:
It appears you have the same leveling system as we do. Note that on page four it says to change the fluid every 36 months. This is a system that a lot of people ignore unless there's a problem with it. When we got our rig, I couldn't tell what was in it or if it had ever been changed. Ours was seven years old at the time, I had the fluid changed so I knew what was in it. Then I put a large Dymo Label on it with the change date and what was in it.
Bill
There is NO REASON to change out Fluid in a Slide/Jack system. LCI does state to do so, but there is no valid reason to do so. There are NO gears or moving parts to overheat or get debris in the system. Replace if it makes you feel good, but it is not necessary. Doug
