bobndot wrote:
If you install a set of bubble levels that you see from the drivers seat, like I did or Dusty did, there will little need to level other than move the rv into a suitable position. If you use decent private CG's many will already be level. I seldom use my hydraulic levelers and would not spend $5k for the option.
If you do use wood blocks or plastic blocks, use your awning strap rod to push them in place and attach a rope to them to remove them. Limited bending down.
Using the awning strap rod is a great idea! I'll have to try this, along with the extra thick kneeling pad I use.
