dougrainer
Nov 15, 2016Nomad
Yes, you can swap the 2 wire connection from another solenoid. IF the jack then retracts, your fuse is blown for that solenoid. Usually, if the fuse is blown, the cause is a shorted solenoid. IF the solenoid is shorted, it will blow the fuse for the swapped solenoid. The replacement solenoids are on backorder. HWH has been out for a few months. You may have to get it from another RV service center that has HWH parts in stock. Doug
