dougrainer wrote:
OnaQuest wrote:
dougrainer wrote:
You use the jacks to do the complete level. You do not have to use blocks. The jacks are more than capable of supporting your RV. IF you have a Gasoline model, then movement and "bounce" will be normal even with the jacks leveling the RV. Doug
This is not necessarily a true statement. Properly leveled, a gas MH is as stable as any other and will NOT move or "bounce". The extra weight of a large diesel rig certainly helps in stability with jacks up or down.
Yea,what do I know. I have ONLY been in the RV service business in motorhomes for 35 years and have installed countless jacks on Gasoline motorhomes. Diesel rigs, when you dump the air bags, that drops the motorhome down "solid" on the chassis frame and there is hardly any movement because of that. Gasoline motorhomes still have leaf/coil spring type suspensions that the jacks cannot overcome. THAT is why they still have some movement. Doug
35 years of experience for some folks can sometimes just be "One years" experience 35 times. Not too impressive.
First, ALL motorhomes are attached
directly and solidly to the chassis frame. The diesel air bags are positioned between the chassis frame and the suspension (NOT between the the MH and chassis), just like a sprung gas chassis.
Levelers (jacks) bolted directly to the chassis frame (as my PG jacks are) are capable of lifting enough weight off the springs to prevent ANY bounce or movement from people walking around inside.
If the jacks that you installed could not prevent bounce and movement of a gas chassis mh, they were either not operated properly or were not installed properly.
BTW - I didn't just enter the RV world yesterday, myself.
