camperdave wrote:
Not only that, but there's only one tank unlike a typical towable. So when you're out, you're out. And of course propane gauges are not exactly accurate... Mine at least shows empty when there's still at least a 1/4 tank (usable) left. I end up filling up before I need to, but without a changeover valve and second tank I'm not sure what else to do about it. :?
The gauge on the propane tank itself should be more accurate than that (it's a mechanical float in the tank), though it's often rather obscured by the sender for the display inside the motorhome, and sometimes is not in a very visible location at all.
