bob_nestor
Feb 28, 2017Explorer III
Brake life on any vehicle depends a lot on how the vehicle is driven, especially those with automatic transmissions. There are a lot of drivers who "ride the brakes" causing a lot more wear on the brakes. There are also drivers that I call "binary drivers". These are the ones that go full throttle or full stop and that requires more use of the brakes. The ones who anticipate stops and coast to slow down before applying the brakes will get a lot more brake life.
Then too, it depends on where the vehicle is driven. If it spends more time in mountainous terrain the brakes probably get used a lot more. Of if it's driven on gravel roads the dust, dirt and small rocks can do a job on the pads and discs. Had to totally replace the discs an pads on my Jeep after towing it to Alaska and back and running all over up there with it.
38,778 PostsLatest Activity: Jun 03, 2026
