hdeddie1 wrote:
Well after reading everyone's posts, I decided to pressure wash and clean the area and located the three bolts and the each took a half to three quarter turns. Did the trick. It is no longer leaking. How long that lasts is anybody's guess. I will keep a close eye on it. And in the event it doe's need to be changed, I've decided to do the job myself. I got lots of good advise on the forums. Thanks for all of your help. Ed.
It is prone to leakage in two place. The three bolts you tightened and the electrical entry area. I did what you have done to keep from being stranded and then had the pump replaced at my liesure in order to prevent another stranding situation.
