Gjac wrote:
DryCreek wrote:
Gjac wrote:
I'm not sure if it is a function of age or hard water but when my white hose had a pin hole leak I cut it at the pin hole to
make a splice what I noticed was a brown build up on the inside of the hose. I now look inside mine every now and then. My original hose was about 10 years old.
Sounds like iron deposits to me. Was is reddish-brown in color?
No just brown. That is why I cringe at some of these threads about buying these expensive "potable water hoses" that last so much longer that the cheap Walmart brand.
Not much you can do about the water quality at the source cuasing the buildup inside the hose, but the "potable water hoses" are so named because they are supposed to be manufactured without harmful PVCs and other toxic plastics or rubbers that can leach into the water and ultimately into your body.
