I have recessed lighting in the kitchen over the sink of our HR Augusta. I would like to swap out the incandescent bulbs for LEDs as the current bulbs run really hot. The fixtures pull straight down ...
Coil spring. Will try that. But, what’s the secret to attaching pictures?
Ok,...all the lights are held in with two coil springs, one on each side. I was reluctant to pull down too hard on the fixture, but with gentle pressure the springs slide through the opening just fine. Also, I discovered that the bezels rotate off. Now I just need to find LED bulbs to replace the incandescents. Since the bulbs aren’t imprinted I’ll need to take a sample with me. Unless they are pretty much universal?
