msmith1199
Aug 26, 2013Explorer II
SS Slacker wrote:
I have a 2003 HR and suspect I have the same panel as you. I also have the two red switches next to each other for the Water Heater. One Propane and one 120V. BOTH switches light up red when they are turned on. The propane also has a small red dot next to it for ingnition, but yes, both red switches are lighted. I had one of those red ones burn out and I bought a new replacement switch from the dealer for around $6 and replaced it as I wanted them to be lit when on. After unplugging the harness and squeezing the prongs the entire switch pops out and the new one goes in.
In short, Yes, they both should light up when on.
On the small red propane dot, doesn't that only light up after the main propane heater has failed to ignite? The only time on my panel I've seen that light up is when the water heater tried to ignite a few times and failed and then it timed out and the light came on.
38,774 PostsLatest Activity: May 13, 2026
