road_glide
Aug 27, 2013Explorer
SS Slacker wrote:msmith1199 wrote:SS Slacker wrote:
I have a 2003 HR and suspect I have the same panel as you. I also have the two red switches next to each other for the Water Heater. One Propane and one 120V. BOTH switches light up red when they are turned on. The propane also has a small red dot next to it for ingnition, but yes, both red switches are lighted. I had one of those red ones burn out and I bought a new replacement switch from the dealer for around $6 and replaced it as I wanted them to be lit when on. After unplugging the harness and squeezing the prongs the entire switch pops out and the new one goes in.
In short, Yes, they both should light up when on.
On the small red propane dot, doesn't that only light up after the main propane heater has failed to ignite? The only time on my panel I've seen that light up is when the water heater tried to ignite a few times and failed and then it timed out and the light came on.
Yes, that is correct and like mine also..I should have said "ignition failed" for the small red dot
Thanks for the input...wanted to respond before I go off looking again for a "replacement" lighted switch and a lighted indicator light....
I will check the tech section...
Got 2 pictures of my monitor panel for you and 1 of the indicator light for house batteries which is also inop...
Are we all OCD? (obsessive compulsive) or just being safe?
38,774 PostsLatest Activity: Mar 01, 2019
