SS_Slacker
Aug 27, 2013Explorer
road glide wrote:
So..in the above pictures you can see the propane indicator light works as well as the ignition failed dot light(just turned it on for a moment to show both lights work), but the 120 volt light is out and I will hunt that down and R & R.
The House power on light is also inop, but it is just an indicator light, different than a switch light. It's a quick fix, whereas the entire monitor panel requires removal (about 8-10 screws)...to get behind the 120v water heater lighted switch..to be cont...
Found one source already....
lighted switches
and another..
more lighted switches
Well, for me it is the OCD and I fully admit it. I have replaced a couple of those lighted switches as well as some of the lights that are next to the switches. Some of them I need like the cargo bay master switch light indicator and some of them I replaced because of the OCD.
I have this need to have everything in my RV work the way it is suppose to, so I replace or repair anything that does not work as designed. Based on your pictures we have the exact same panels and other than removing and replacing the panel screws, it is a quick and easy job. Also, you may want to consider ordering an extra switch and indicator light. I carry spares now and when one goes out now I can replace it immediately
38,775 PostsLatest Activity: May 14, 2026
