John&Joey wrote:
Old-Biscuit wrote:
Converters don't cycle on/off....are always on when AC power is supplied to them
DC Output voltage will change from 13.2V (float mode) to 13.6V (absorption mode) to 14.4V (bulk mode)
Converter is supplying the DC System (Lights, circuit boards, water pump, furnace etc) when AC Power is supplied to them PLUS maintaining battery voltage.
Well that sounds like some old school book smarts, but 'splain me this Lucy. When I bought my rig the PO just installed a new battery and a new "smart" converter (per his words.) When my lights go dim the OEM battery meter shows 3/4 charge. When the lights jump up to bright, the OEM battery meter reads full charge. :h
Do you think it might just have something to do with preserving the lifespan of a deep cycle battery, like there might be some science to that also and there could be a bigger picture to this simple problem. :E
Sounds more like you have an issue..........
Have you checked out your actual DC voltage using a multimeter?
Lights should not be dimming/going bright
