Southwind98 wrote:
Agree with those posting it most likely the converter. Experience the same symptoms several years ago with lights dimming on our 08 Bounder. Had to replace the converter, which was a straight forward job. My converter was located behind a rear bedroom drawer.
Posted this on a previous post a couple of years ago:
If you do need to replace the converter I highly recommend best converter http://www.bestconverter.com/
They were recommended from many others on this forum. I was very happy with my dealing and purchase from them. I purchased the Power Max Boondocker 75 amp
I have found that this is the best performing and lasting converter out there. It also seems to use less AC power, which is important when using a smaller generator. We went from a 40 amp, to a 70 amp for boondocking, but found it really pulled a lot of power when first placed on line while boondocking. When it died, we went to the boondocker 60 amp and it does not trip the 2,000 watt inverter generator when first plugged in.
