luvdoggiez's avatar
luvdoggiez
Lights on '03 Alegro Bus Instrument Cluster
Hi there Everyone,
We have a 2003 Allegro Bus on a Freightliner chassis. The gauges work, but the lights on the instruments do not turn on when we turn on the marker lights or headlights. The marker lights all come on, but nothing on the instruments. We've tried adjusting the dimmer switch and that doesn't do anything. We've checked all of the fuses behind the gas/break pedal and didn't find any blown fuses. Any suggestions would be greatly appreciated.
Thanks!
Eric and Carol Anderson
  • I have the same year MH.
    There is a separate dimmer switch for the instrument lights. The headlight switch turns like a normal dimmer, but seems to do nothing. The separate "dimmer" switch controls the intensity of the lights on the gauges.
    I'm guessing that you knew that their are two separate turning knobs, but just in case.
  • TRVN is a great resource and, like 67Cutlass, I use it daily as well. I'll almost bet your problem is a burned out light bulb or bulbs but you might have to pull the panel to find it.
    Another good resource for you is the Tiffin Service Department. Give them a call. Just because your coach is 10+ years old doesn't mean they won't talk to you and try and help you solve the problem.
  • We have a Tiffin Phaeton and I use the TiffinRVNetwork Forum almost daily. I have found the forum to be VERY helpful and respond quickly to your Tiffin questions. There are about 1200 active members on that forum. This forum is not associated with the Tiffin Motorhome company.
    No offense to anyone here, but the TiffinRVNetwork Forum members really know and understand all Tiffin products.
    So my suggestion is to post this question on that forum. You will be surprised how quickly you will get suggestions and answers that you need.
  • I'm not sure what TMH did that year, but I had an 03 Winnebago/FL that had a separate dimmer switch for the instruments. The dimmer on the headlamp switch controlled the drivers map light.
