I have a 2004 Jamboree 29S. I discovered the following lights out: reverse lights, parking lights, and the rear clearance lights. The brake lights do work as well as the head lights and the front c...
FYI, the screw terminal wire connections to the fuse individual holders can become loose and cause various 12 volt items to work erratically or not at all. I found a loose screw connection at a fuse holder while checking fuses, got my AC thermostat working. Phew!
