dougrainer
Jun 13, 2013Nomad
The Trombatta solenoid is not the reason. LCI uses a PRESSURE switch to indicate jacks retracted. IF that pressure switch does NOT see and sense the static pressure on the system the Down light comes on. Doug
http://lci1.com/images/Flyers/LIPSheets/leveling/0008-pressure-switch-flush-fill-fitting-change.pdf
38,782 PostsLatest Activity: Sep 10, 2026
