Goldencrazy wrote:
Is there a general pattern for what outlets are hot when inverter is on or do I just need to plug something into each and use trial and error to discover? I know generally the front media center is hot and the mid tv. Are GFI's generally connected as inverter circuits?
GFIs should work with the inverter......I will say tho that I have 2 inverters and the GFIs didn't work when #2 went bad.
What are you running?....someone will have a similar setup I'm sure.
Merry Christmas........Ol'Ben
