Goldencrazy wrote:
Is there a general pattern for what outlets are hot when inverter is on or do I just need to plug something into each and use trial and error to discover? I know generally the front media center is hot and the mid tv. Are GFI's generally connected as inverter circuits?
I don't see 2016 wiring diagrams up on the Winnebago website yet, but here's the
Body, 110 Volt Wiring Installation/Diagram for the 2015 Suncruiser 38Q. If you check the wiring diagram on the last page it will tell you which outlets are on the inverter.
