pnichols
Jul 27, 2013Explorer II
charlesvalentine wrote:
They definitely won't be the same diameter. I figure if I lose a rear tire I'll just switch a front to the rear and put the slightly different size spare on the front. I think it is fine to have a slightly different sized front tire on one side, do you agree?
You have a large and heavy Class C. Who's going to change your flat tires on a trip - probably your Emergency Road Service (ERS)?
If you were to have a flat on an inside rear dual along a busy highway or along a remote highway with fairly steep and/or soft shoulders - not the best of situations to have a tire failure in - the ERS will have to both get at and remove the inside rear dual failed tire, plus take off a front to put there, plus put the spare on the front. I don't see all this happening in many emergency situations.
Remember that with a failed tire in any position in the rear, you CANNOT merely continue driving for miles counting on the remaining good tire of the dual set to carry the entire weight of that side in the rear until you get to a good spot for the ERS to make the mulitple tire changes required. This situation places a tremenduous over-load on the remaining good tire of the dual set and it is then very dangerous to move much at all this way ... especially with a large heavy Class C.
It's best to always carry a full-sized spare and wheel of the same load rating and size as the running tires on your RV. Also, keep this spare inflated at all times to the HIGHEST inflation pressure (usually the rears) that you are using on any of the running tire positions.
BTW, you might want to verify that your current ERS will change failed inside tires of dual sets on motorhomes. We recently found out that our ERS (we're been with them well over 30 years) has a policy TO NOT CHANGE failed inside tires of dual sets. We reluctantly dropped them and signed up with another ERS that had no policies against full service on motorhome tires in any position.
