pconroy328
Mar 16, 2015Explorer
Loaded Question: "How easy is it...?"
I know the answer will be "It depends" but I'm looking more for the "Yeah - go for it" or "No way! Let a shop handle it" response. :)
We're in a New To Us 2008 Coachmen 21QB. I always wondered where the Fresh Water Tank was. I found it this weekend when I removed a shelf and brackets from the storage area.
Yep - you guessed it. They drilled five screws for the brackets right into the tank. Watching water drip from a spot it wasn't supposed to, tipped me off.
I patched the small holes. Epoxy. They don't leak. But it's clear (pun intended) that there's rust accumulation inside the water tank. It's gross.
I've got bleach in there now, to tide us over Spring break and we'll bring bottled water.
But DW wants a new tank. It's 50ish gallons and seems to be 14 x 22 x 38". Fittings look like they're by the opening. Looks like it'll slide right out.
So the loaded question is -- would you tackle the fresh water tank replacement yourself? Or is there something magical that would make you take it to a shop?
I've already found a website that looks like they have a replacement for $290.
Thanks!!
Thanks!!
