BCJim's avatar
BCJim
Locating Leveling Control Module
We have a 2005 34ft HR Vacationer on a workhorse chassis. Last trip out the jacks would not work at all. Also theres no lights on the dash piece. Took it to an RV mechanic and after approximately 8 hours, on and off, he can not locate the leveling control module. He removed the dash, tried to follow wires, called HR or Monaco and nothing. Called us to come pick it up and if we find it, bring it back. Well, we cant find it either! Hope someone can help,
thanks, BCJim
NOTE: Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★" located at the top of this forum?
    "Forum Posting Help and Support is reserved for questions on how to post in the forums, signature and photo testing, reporting website or member account issues. Please avoid using Forum Posting Help and Support for RV related questions, as doing so can delay responses to your thread. Instead, create future threads in the RV FORUM which corresponds to the subject of your topic. Thank-you!"
  • Thanks for the responses. The make of the jacks is power gear. We have checked the chassis fuses and gone through them 1 by 1 we have also checked all compartments and I paid a mechanic for 6 hours to check under the rv and in all spots that he thought it would be. We also contacted Monaco and they had no idea on where it would be. We are looking for the Main Power Connector #500457. Thanks for any further answers
  • As a few have said, look in the compartment area. I had to crawl in and lay on my back and look up. It's not very large and there is power on mine there that feeds the control panel at the driver seat and I had managed to knock the connector off sending the power. I was storing a collapsible trash can on top of the frame. :)
  • 4x4van's avatar
    4x4van
    Explorer III
    I think I'd be looking for a different RV mechanic.
  • BRAND of the Jacks will help a lot in determining a solution to your problem. Doug
  • The leveling sensor should not prevent the control from coming on.
    It is not getting power for some reason.
  • On my Georgetown it is on the ceiling of the bay closest to the hydraulic pump
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    The leveling control module is the button pad in the cockpit
    THe leveling sensor module is .. Well on my Damon Intruder if you draw an "X" from the right front tire to the left rear. and the left front to the right rear.. X marks the spot. in the basement on teh "Ceiling" of the compartment.
  • Make and model of your jacks?
    Sounds like blown fuse in the chassis power distribution panel.
