bigdisplay
Mar 16, 2015Explorer
goofyphd wrote:
I realize that the subject of nonfunctioning levelers has been addressed previously. However, during troubleshooting of my nonfunctioning levelers I realize I cannot locate a fuse that may be the source of my problem. Can anyone help me locate the 40 amp fuse on the (black) 6100 wire? 2003 Itasca Suncruiser IFG33V Workhorse Chassis with HWH 310 leveling system.
Gary
all The systems from HWH that I have worked on have a 30 or 40 amp fuse in a inline water proof holder right at the motor/solenoid system
HOWEVER there is also a control system fuse(10 amps) usually found in the main 12 V fuse centers If either fuse blows system will not function
NOTE If the panel lite lite up its not the fuse in the main fuse center "BUT" there is also a FIVE amp fuse right on the end of the HWH controller usually found under the dash on the drivers side on older models but again if the panel lites display it also not this fuse
38,778 PostsLatest Activity: Jun 05, 2026
