Gene_M's avatar
Gene_M
Location of battery isolator & relays in '04 gulfstream 5230
Since there is little to no documentation on my MH I have been systematically going through the various systems to identify the components and am up to researching the electrical system components and their location.
I am currently stuck on the manufacturer and installed location of the battery isolator and associated relays. Does anyone have info on these as installed in the 2004 GS B-Touring Cruiser 5230?
Thanks.
  • Hey Glenn, if you're still watching this thread...
    I just found the boost relay and battery isolator I was looking for .... they are mounted on the outside, rear of the battery box which faces the center of the chassis.
  • Never had much luck finding the relays. Had to move on to other projects. Electrical system is functioning correctly now that I replaced the house battery, an automotive battery previous owner installed, with a DieHard deep cycle battery.
  • I wonder if Gene ever found the boost relay... I'm looking for mine and cannot find it anywhere .. I looked
    • under the hood
    • under the chassis below driver
    • in elec dist box
    anyone have another suggestion?
  • Thanks Glenn, nothing like that in my battery compartment, although there are 3 circuit protectors in there.
  • Thanks Bud, RJ, CG, and Dusty.
    My steps are in the back of the coach on the curb side and the battery is in a coach compartment that is outside behind the driver's seat, there are 3 circuit protectors also in that compartment. Possible that they could be behind that, under the coach, I will look.
    I will check under the hood and if nothing turns up we'll do the battery switch and listen for a solenoid in different areas. (there is a black box under the driver's seat, so maybe a quick switch/listen there would be a good/easy starting point)
  • We had an '03 Itasca. That relay was behind 2 panels in an out side storage boot. The first panel was the back of the boot. Behind that there were some fuses mounted, then behind that panel was the relay.
  • Have you checked under the side steps? Sometimes the compartment is divided in two, with half housing the house batteries, and the other housing some electrical components.
  • There is an overall lack of standardization in the RV industry. However, I used to have a 1998 Gulfstream and it did not have a manual battery switch or disconnect. It did have a solenoid for charging the coach battery under the hood on the driver's side. It looked exactly like an old-style Ford starter solenoid (which is probably what it was). Your coach may be completely different, but hopefully this info will help.
  • Have a helper operate the battery disconnect and listen for the relays to energize and de-energize. Some are stuffed under the passenger seat.
