dougrainer
Mar 02, 2017Nomad
2000 Newmar Diesel Pusher, the CHASSIS battery starts the Genset. IF the Diesel engine starts, but the Genset does NOT, then either the 12 volt battery cable system from the rear to the front has loose or corroded connections, or the Genset has a problem regardless of 12 volt supply. If your Chassis engine does NOT start, then that battery is your problem. The Chassis batteries are located in the Passenger side rear most compartment. The Coach batteries are also located in the same compartment. They are on a slide out tray. Doug
