djbroughton's avatar
djbroughton
Location of fuse for water pump- Monaco Coach
I am installing a new water pump and have blown power leading to the controller governing the pump. I can't find a marked fuse for the water pump in either the fuse panel on the back bedroom wall or the main fuse box on the outside of the coach below the driver's area. Does anyone know of another fuse location on this coach?
  • Problem solved! I have now replaced the pump and the Intellitec switch controller but could still not get the pump to work through the controller. After tracing the hot wire from the pump, I discovered a 40 amp relay sitting at the end of a pig-tail beside the other fuses on the bulkhead wall. After replacing this relay, everything works fine.
    Thanks for all the suggestions.
  • I have a pump switch in the control panel and also one in the wet bay. I have noticed when the switch in the wet bay is in one position the switch on the control panel doesn't control the pump. I never did figure out their wiring on that switch. I only noticed that when I was switching the two switches then went inside and pump wouldn't turn on. Went back and flipped the switch and had power inside on the pump again.
  • WyoTraveler wrote:
    Although they change from year to year my water pump fuse is #14. It is the second up from the bottom on the right side in the fuse panel in bedroom. It is a red 10 amp fuse. I have a 2013 Monaco although not your model.
    My water pump fuse in the bedroom fuse panel is #7 and this one is good. If there is a fuse there, would there be another one elsewhere?(other than the inline fuse on the water pump)
  • mscamping wrote:
    Look for an inline fuse at or around the pump.. Mike Mathews..
    Thanks but it's not that fuse, the power loss is in the coach somewhere.
  • Although they change from year to year my water pump fuse is #14. It is the second up from the bottom on the right side in the fuse panel in bedroom. It is a red 10 amp fuse. I have a 2013 Monaco although not your model.
