Jim_Bakker
Oct 11, 2004Explorer
We took delivery of our Pace Arrow on New Year’s Eve, 2003. It’s the 36B floor plan, with cherry stained interior wood. We are very happy with it, and since I’m 6’8” tall, the 7’ ceilings are much appreciated!
We’ve put nearly 9,000 miles on it, all here in the West. The powertrain has been solid and impressive. We recently learned that some of the Workhorse chassis built prior to sometime in the spring had been equipped with undersized shocks. Our local Workhorse service center confirmed that our coach had this problem and Workhorse authorized replacement of the front shocks. Have only driven it from the shop to the storage yard, so I don’t yet know how much they have improved the ride and handling.
We’ve had some problems, but nothing really serious, although this could have been if I hadn’t noticed it while we were parked. The screws securing many of the storage compartment hinges had been over tightened causing the heads to break off. I noticed that one of the doors was mis-aligned, and when I opened it to see what was wrong, the hinge came completely off. Fortunately this happened when I was holding it and not on the highway at 60MPH.
Other problems…
Right from day one the automatic leveling system has lost stability, overnight at first, now right away because one of the jacks almost immediately lifts off the ground. It goes into the shop next week and I hope they can fix it this time. Has anyone else had problems with the leveling system? I recently met someone with a 2005 model; it has a different brand of leveling system, not PowerGear. Is this an indication that Fleetwood recognized a problem?
When showering, lots of water flows from the backflow prevention valve on the shower faucet hose, regardless of where the shower head is positioned relative to the backflow prevention valve. The dealer has ordered a new hose and faucet, but I’m skeptical that will solve the problem. Anyone else had this problem?
The button atop the kitchen faucet, that converts the flow from a stream to a spray, won’t lock in place. The faucet will spray as long as the button is depressed, but once released the flow returns to a stream. Our home faucet doesn’t work this way; once pressed, the button stays depressed and the flow continues as a stream. How does the faucet in your coach work? Will it lock into spray mode?
Here’s a funny one that has been fixed. The compass would never read correctly. Turns out the sensor had been installed right next to several of the surround sound speakers, whose magnets were confusing the compass. Now that the sensor has been repositioned, the compass is working fine.
Other problems…
38,705 PostsLatest Activity: Jan 14, 2025
