- Paul_TurpinExplorerHas anyone replaced the RV frig with a home type frig?
- Meme_RayExplorer
sawellman wrote:
Has anyone upgraded your air conditioners? Camping in the heat this weekend I am finding that mine dont really cool my RV that well and would like to upgrade.
I don't think upgrading your air-conditioners likely solve your problem. We had a similar problem in 2006 when temperatures were extremely high 100 to 115 on a trip to Memphis/St. Louis. We actually burned up our shore plug and had to replace it on that trip. Our unit is only 30amp so now in extreme heat when the air-conditioners run non-stop we only run one of the air conditioning units at a time and also run the fridge on gas instead of electric. We have thought about rewiring one of the air-conditioners to a separate circuit/plug so that we could plug it in by it self and thus use the 30amp and the 20amp plugs in most campground hook-up electric boxes. We looked into upgrading to 50amps but thought it wasn't worth all the effort.
Meme - LobstahExplorerNever had an issue with ours, but we haven't been out in 100deg lately.
Maybe they need to be serviced?
Jim - sawellmanExplorerHas anyone upgraded your air conditioners? Camping in the heat this weekend I am finding that mine dont really cool my RV that well and would like to upgrade.
- rag-ftwExplorer
Lobstah wrote:
Ready Brake here. Very little work required on the car, it's a steel cable that runs from a lever on their receiver, through the front of the car, around the engine compartment, through the firewall, and clamps to the brake pedal. As your MH slows down, the car pushes forward on the receiver, which in turn pulls the cable and the brake pedal. Very little to break, and very simple system.
Jim
Just completed a 5,000 mile trip from TX to AK with a Ready Brake system. It worked great! I did find that I had to allow a little more slack in the cable than the installation instructions indicate to allow for the frost heaves.
bob g - rag-ftwExplorer
Lobstah wrote:
On a different note...
For the 3yrs we've owned our 36D, one of the things that has bugged me is the glass cabinet doors and the way they rattle when going down the road. No matter how tightly I pushed those silly rubber retaining strips into the slots, they still loosened up and the glass would rattler.
Finally had some time on the last trip to pull all the doors off, remove the strips, and apply a healthy bead of silicone caulk all the way around the glass. The trip home, over rough Mass highways and bridge joints was MUCH more quiet.
Easy project, huge payoff.
Jim
I took the glass out and replaced them with mirrors so the DW could use the cabinet for food storage. The mirrors were thicker than the glass and worked well with the retaining strips.
bob g - Meme_RayExplorer
Jim Bakker wrote:
Smoke from a nearby forest fire caused my CO sensor to go off last night.The alarm wouldn't stop sounding, and the crimp connections prevented easy disconnect, so I took the brute force approach—cutting the wires. That stopped the alarm, but it also disabled the propane alarm and the tank sensors. Does a CO sensor have to be wired into the circuit? Or did I blow a fuse? If so, where is the fuse located? All the coach fuses in the panel cabinet seem to be OK, and besides none of the labels seem to apply. Thanks for any help you can provide.
Sounds like a similar problem we had a few years ago and it took us quite a while to rectify the problem. The Smoke/CO alarm in our bedroom went off one night for no reason and pressing the reset did nothing. We ended up just yanking it off the ceiling in the middle of the night so that we wouldn't wake up the whole campground. We never did find the source of the malfunction but eventually found some writing on the smoke/CO alarm that indicated they actually have a life span and that ours should have been replaced a few years ago. I found an identical one on the internet by searching for the make and model number. There was one version that was hard wired and had a battery and one model with just a battery. Make sure that you get the right one because they look identical in the pictures. we need the one that was hardwired and had a battery. We had to spice the wires since we had ripped it off the ceiling but it worked great. I do think that there were some instructions about pressing a reset button or doing something else special during installation to get it installed properly. If this step wasn't followed the new unit beeped like the battery was bad. Seems to me the hard wired replacement unit was less that $35 that our local RV store wanted for the battery only unit. Good Luck. - Jim_BakkerExplorer
Jim Bakker wrote:
I decided to take care of this today. One of the fuses labeled LP Detector was burned out. Replaced it and all is well! Thanks for your help!
I'll stop somewhere along the way tomorrow and buy fuses and a puller. - Jim_BakkerExplorer
Jim@HiTek wrote:
another place to check would be inside that big box in or near the battery compartment.
Found two 3-amp fuses labeled LP detector in the Battery Control Center. Don't want to mess around in there without a fuse puller, but I'll stop somewhere along the way tomorrow and buy fuses and a puller. - JimExplorerIf you cut one wire at a time it's doubtful you blew a fuse. If you cut two wires in the same go, then you probably did.
Most house fuses are near the circuit breaker panel but since you've already checked there, another place to check would be inside that big box in or near the battery compartment.
38,763 PostsLatest Activity: Mar 21, 2016
