- Deputy_Chief_P_ExplorerI own a 2003 Pace Arrow 36B (as of a couple of months ago) and just discovered this thread. I read all 82 pages. I am just wondering if anyone has any pictures of any modifications that they have made to their rig. I am always looking for new ideas
- Paul_TurpinExplorerUntil you get the code you will never find the problem. If you get the code or codes (you might have several things going on) post them, someone here must have the codes. If not there are other forms that have them.
- R2DillonExplorerTake it to an auto store and have them read the codes. Many of the systems gather data prior to changing the light.
- kemdignamExplorerThanks RVMN, I did read that in the manual and online and saw that was a common issue. My fuel cap was/is on tight. It is almost like the light triggered and now it won't go off.
- RVMNExplorerKaren,
First and easiest thing to check is that the fuel cap is installed and tight. - kemdignamExplorerI was told to put some STP in my tank if I ever filled more than 50 gallons at a time. After I did this, my engine light came on with no degredation to my engine performance. The mechanic suggested that I disconnect the main battery to get the light to go off, but that didn't work.
Any suggestions?
Thanks in advance!
Karen - Paul_TurpinExplorerfollow the wires from the wiper to the first large wire block in the engine compartment. Open the wire block and dry it out and clean the pins. Put it back together and cleck your wipers, if they work put duck tape around the block to keep water out. Good luck I hope this will fix it.
- PaceArowExplorerWe have an 05, Pace Arrow, 37C, on a Workhorse 24... The windshield wipers just stopped working in the rain. It has been a week and they are not coming back on. The washer fluid no longer works either. I checked all fuses an wires, including ground, and all seem fine. Any suggestions would be greatly appreciated.
- Paul_TurpinExplorerI got the lens covers a few years ago at www.rvpartstore.com if you don't see the lens on their site. give them a call.
- picayune_1ExplorerLove this site but keep losing it. Need to find lens covers for light over door and light on driver side above hookups. I can find the whole light but can't find where to buy just the lens. I bought 4 lens in Alabama but forgot where? Thanks
38,743 PostsLatest Activity: Aug 06, 2025
