- seatecExplorerAny of you have experience with a leaky sky light causing damage to the ceiling? It seems my insurance covers it but want to ask you guys for an opnion first before I knock on their door. I had the MoHo stored for a while and for some reason a skylight cracked and water ruined a big portion of the ceiling. It also looks like I have some mold now.
- MrMudstudExplorer
Lobstah wrote:
And speaking of wheel covers, I lost a nut, as well as the actual funny sized lug that goes behind it. Anyone know where we can get those? I believe my lugs are actually metric. Jim
The only hope that I can think of, is to check with different dealers to see if they have an extra one. Of course there are 2-3 different sizes and designs. Maybe if you are lucky, you could contact the manufacture to get one. Did you try e-bay? Good Luck - Fyr_guyExplorerThanks guys! I actually found my socket it was an 1 9/16. All is good.
- LobstahExplorer
MrMudstud wrote:
Mine takes a 1 1/8" socket for my wheel covers. I keep an extra one in my tool bag with an extension already assembled together. This tool is ONLY for my wheel covers and is in my RV tool bag along with the 1/2" ratchet. My other wrenches are in my mechanic tool case. Since I use it often, I keep it handy in my general tool bag.
Jim - MrMudstudExplorerMine takes a 1 1/8" socket for my wheel covers. I keep an extra one in my tool bag with an extension already assembled together. This tool is ONLY for my wheel covers and is in my RV tool bag along with the 1/2" ratchet. My other wrenches are in my mechanic tool case. Since I use it often, I keep it handy in my general tool bag.
- JimGoExplorerSimulator Wrench is 1 5/8 I believe
- Fyr_guyExplorerAnyone know the size of a socket to use on the front hub caps. I bought one several years back and it seems to have walked away??
- LobstahExplorer
FreshAir wrote:
Lobstah, I have had my handle light burn out butI don't think it had any effect on the porch lite. Pretty sure.
I was buying my lenses for the porch lite from Fleetwood but had to buy the complete lite assembly, about $9 as I recall. Bought 5 of them as the diver side coach lite took the same part. I now would probably buy the complete LED asy. that some are now using.
Pat
The LED assemblies is what I installed. I don't believe that the handle light and the porch light burned out at the same time...I'm fairly certain that I have a problem with that circuit, I just don't know what fuse it's on. Won't be using the camper for the next 2-3wks, so won't be able to poke around the fuse panel with a test light until then.
I thought maybe someone had had to replace that fuse already.
Btw, the LED lights are much better than the orange glows that were originally on the rigs, and were VERY easy to install. Their base is bigger than the old light, so it covers everything up nicely. Just put a good bead of sealant on the new light, and make sure you carefully clean all of the old stuff off before you put the new one on.
Jim - FreshAirExplorerLobstah, I have had my handle light burn out butI don't think it had any effect on the porch lite. Pretty sure.
Pat - LobstahExplorerPosted this a few weeks ago in "general", but some here may not have seen it.
I replaced my porch light last spring because I was never able to find lenses for it, and my front and rear light lenses were both rotted.
About 6mos later, we were setting the coach up for winter camping, and my porch light wasn't working. Put it on the list of "stuff" that we all have.
The next weekend I noticed it wasn't just the porch/entry light, it's also the handle, which I'm thinking has to be on the same circuit. Took a quick look at the fuse panel, didn't see anything that seemed directly related to the entry light/handle, and haven't had time to dig into it since, but should have a bit of time coming up.
Anyone else run into this on our Pace's?
Thanks,
Jim
38,740 PostsLatest Activity: Aug 01, 2025
