- rolnhomeExplorerwhat recall notice
- bricotExplorerAnyone got the recall notice yet? Curious if it will affect the 36B...
- seatecExplorer
dkingdoe wrote:
seatec wrote:
Question,
Have the KIB C07 monitoring panel. Strange thing happend. i pressed the frsh water tank button and the led briefly lit up and then went out. now none of the water indicator LED's or the battery level display work. everything else on the panel like the slide and water pump buttons work. Just not the indicator lights or display. I checked all fuses under bathroom simch and in fuse compartment next to door steps but cant find a blown fuse. Anybody have an idea what this could be? I also didnt see an inline fuse anywhere when i pulled the panel to look behind it and the plug is firmly seated.
Thank youdkingdoe wrote:
We had this problem back I few years ago. I'll go look thru our repair records to see what the solution was and post what I find.
--dk
Seatec >> I went and looked thru our repair records and the solution was...the fuse for the monitor panel is a shared fuse with the CO2 detector + monitor panel. That fuse is located in the fuse compartment next to door steps. Check the fuse marked 'CO2' to see if it's blown. I know it sounds crazy but that was our problem.
Hope this helps.
~~ dk
Thank you. i will check that tonight. i wonder if that is also the reason why my controls or the adjustable air mattress arent working.
I will report back. - Meme_RayExplorer
Papa Mel wrote:
Water Heater
I own a 2004 Pace Arrow, 37C. My water heater works great with propane but doesn't do well with electric. It just keeps the water luke warm. What can I do to trouble shoot the problem? What can I look for?
Thanks,
Mel
Papa Mel:
Have you checked to make sure that your outside water faucet is not accidentally turned on. This would make your water heater operate improperly.
Meme - Meme_RayExplorer
Bird Freak wrote:
Is this the reason my door squeaks going down the road? I haven"t been able to find the squeak and it drives me nuts.
I'd love to hear the solution for this problem too. No matter how tight we shut the door and lock it - it always rattles or squeaks. We have had to have our hinges replaced on the door once because one hinge cracked and the other 2 showed stress fractures but the door still rattles and squeaks.
Meme - Meme_RayExplorerDennis:
The Dometic Air Foil Kit is #3108039.003. We only installed the vent baffles on the upper refrigerator vent. We did not install the burner shield.
We also have had a problem with the propane alarm going off you describe. I check our service records and found that the dealer replaced a bad electrode 2932781020 in the refrigerator.
Hope this helps you.
Meme?Dennis37 wrote:
Meme&Ray wrote:
Refrigerator problems while driving finally solved.
Well after 5 seasons of driving I am happy to report we can finally drive down the road with the refrigerator on gas and not have it continually go out on our 37C. The Dometic air foil kit we installed on the top outside vent (not the bottom vent that we previously tried) has finally fixed the problem. We installed the air foil kit parts in the forward most position and have had 3 successful trips with the refrigerator running.
Meme & Ray,
Do you have a link or part number for the kit?
My propane alarm goes off while driving (never while parked) if I have the frig on propane.
I have had the system checked for leaks none found.
Thanks in advance for you help. - dkingdoeExplorer
seatec wrote:
Question,
--dk
Hope this helps.
~~ dk - dkingdoeExplorer
seatec wrote:
Question,
Thank you
--dk - seatecExplorerQuestion,
Have the KIB C07 monitoring panel. Strange thing happend. i pressed the frsh water tank button and the led briefl lit up and the went out. now none of the water indicator LED's or the battery level display work. everything else on the panellike the slide and water pump buttons work. Just not the indicator lights or display. I checked all fuses under bathroom simch and in fuse compartment next to door steps but cant find a blown fuse. Anybody have an idea what this could be? I also didnt see an inline fuse anywhere when i pulled the panel to look behind it and the plug is firmly seated.
Thank you - R2DillonExplorerOn the alarm going off. I found that if the batteries were low (usually due to water loss), then the alarm would go off.
38,778 PostsLatest Activity: Jun 05, 2026
