supercub's avatar
supercub
Looking for shop in San Diego for TV/audio/ help
I'm going to be in Santee Lakes near San Diego next week. I'm looking for a good tech that can get all my TV audio systems working. I have Sat TV and it works fine, but can't get it to work on the exterior antenna or the cable feed. I have a switch box, surround sound, dvd player, etc, the typical stuff. Looking for someone that is electronic savy as far as hooking everything up, or checking to see if cables, wires are all plugged into correct spots. Thanks
Brian
    Brian
    check with Santee when you check in....the flyer they give you also has some ads for services in the area.
    Have fun love that campground.
  • If you need to go see an rv shop, there is one nearby in Lakeside called Webb.
  • here you go...start calling
    https://www.google.com.mx/search?q=san+diego+tv+service+surround+sound+systems&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a&channel=sb&gfe_rd=cr&ei=-LmAVOSLGMnE8gfL6IHICw
    as for you sat running to your box/tv from outside connector, make sure your antenna amp. switch is off.
  • I am not an expert and not in the area, but typically the SAT feed is direct from the dish to the receiver. It needs to bypass all switch boxes, etc.
    I have a SAT In line that runs to my entertainment center. I have a separate In line that is for Park Cable of Antenna. I have to change input lines by removing and replacing the cables.
