Hotwheelbill
Jul 01, 2015Explorer
Jim@HiTek wrote:
While I was waiting to 'get round 2 it' I'd just used those strong Zip ties to hold the steps up while driving. One on each side of the step assembly. I'd disconnected the swing arm so the steps were loose though. I never bothered to lash them when I was at a park and they were down. I got use to them that way so as to continue on the trip. They'd swing a little but not to bad. Did concentrate on it though, and used the railings.
If I wasn't going to be at a park for very long, I just set my little plastic step stool out and use that.
Then after the trip was done, and I was at home, took the entire assembly out to work on it. Surprisingly simple system. Easy to pop open the gearbox and check the gears. Lubed everything, cleaned all electrical connectors, and it's been fine since.
Very helpful!
I have two hours in the morning to pull it and see if I can do anything with it.
Zip Ties, Oh I got those!!!!
38,764 PostsLatest Activity: Dec 25, 2025
