- mike_brezExplorerWhen mine did that it was the 200 amp fuse
- myfaceExplorerWhen I lost power, took me some time with help, to find- hidden under dashboard- 40A breaker.
- pianotunaNomad IIIThere often is an automatic circuit breaker between the battery bank and the 12 dc distribution center. It may have failed.
- wa8yxmExplorer IIIMy first tool choice is a 12 volt automotive test light
Brigth = Good
Dark = bad
Dim also bad
Problem exists between Bright and Not Bright
Start with clip any non-painted metal part near battery tip to battery Positive Bright good. Move out along the positive wire to the other end of the wire connected to the battery... Same test. .NOTE.. when you move the ground clip. if possible re-test the last known good spot (Testing ground)
No light on the first test move ground clip to battery - If bright bad ground cable
You come to a box with 2 bolts and wires attached. test all HEAVY wires if there are both heavy and small wires that is your cut off solenoid. - jdc1Explorer IIOr, it could be a bad ground.
- parkmanaaExplorerSounds like your AC to DC converter has a problem.
Need to check to see if AC (120v) is getting to one side of converter,
and if so, check to see if DC (12v) is getting out of he other side. - joelcNomadUsually there is a in-line fuse after the battery. Mine was hidden. Follow the 12V line. Should be with-in 2-3 feet of the battery. Also, if you have a shut off switch check to see if that is on. It might have been moved.
- midnightsadieExplorer IIget your volt meter out start at the battery.
- Matt_ColieExplorer IIHow long have you had this coach?
Does it have a "Salesman Switch near the door?
Start checking from the house battery to the fuse panel.
Matt
38,778 PostsLatest Activity: Jun 10, 2026
