- gboppExplorer
How Dun wrote:
Thank you, thank you, thank you. I found it! It was close to the batteries between the C rails in the basement. I pushed the manual reset button. Good to go.
I love a cheap, easy fix. Especially the cheap and easy part. :) - AllegroDNomadGood to hear. Thank you for coming back and providing the resolution.
- GrooverExplorer II
rgatijnet1 wrote:
Fantastic and keep it in mind for future incidents. My inverter trips from time to time especially during the cooler months when I am using an electric heater. NOw kick back and enjoy yourself.
I have had the same issue. Since I want to be able to use electric heat without worry I tapped into the circuit going to the block heater and put in an outlet that goes through the inverter. There was plenty of room to replace the single gang box for the block heater switch with a double gang (old work) box and put an outlet beside the switch. - prstlkExplorerSo good to help each other!
Funny how major problems for me, can be solved by the folks on this site with ease.
Great Job!
38,705 PostsLatest Activity: Jan 14, 2025
