RJL wrote:
On our way from NJ to Fla our dog bumped into the brake buddy transponder plugged into the power outlet near the passenger seat. That caused the outlet to fall out of the dash somewhat, being held on by the wires. I went over to where the RV is stored while we're on vacation and as I took the outlet out to see what was going on it sparked with the backing portion, that was still behind the dash and barely holding onto the outlet. I proceeded to get the outlet and backing unscrewed and loosened up the bottom portion of the dash so I can get my fat hands back there. I was able to connect everything back together, the wires to the outlet and the power outlet to the backing cylinder that sits behind the dash that screws into the power outlet. Check to see if it has power with my cell phone charger, no power. Checked the other power outlet near the driver seat, no power. Now I'm assuming I blew a fuse but after checking for fuse locations in the owners manual there is no such section. Now I have four fuse boxes, one on the floor of the driver seat, two in the bedroom and one in the engine compartment. Of course there's no legend on any of the fuse box lids. Does anyone know where the fuse for the power outlets would be located. Should I feel confident it's a fuse? I assume there would be one fuse for both but I've been wrong before.
Sorry for the book
Bob
From what you've been saying, it's most likely a fuse.
Many times, the ones on the dash are fed from the chassis panel and the others from the house panel.
When all else fails, pull every fuse you can find and visually check it.
