OK. I got one working today and one still not working. So I have an additional question. I got the driver side one working again by changing the large 20A fuse in the power control center in the engine compartment but the original one on the passenger side is not working. When I disconnected the passenger side power outlet there were two wires, a yellow and white. I plugged the white wire into the back of the power outlet and the yellow wire into the holder I guess you can call it of the power outlet. The power outlet sits outside of the dash and screws into the holder. I'm thinking maybe they're backwards. Is one a supply and the other a ground? I thought maybe one was supply and the other supplied power to the other power outlet, but now that the other is working I see it's not a lead. Could there be two seperate fuses? I pulled them all out of the P.D. box today and all were good. If it's the fuse box under the driver seat it's nearly impossible for me to fit in there. I'm just a bit hesitant to change them around in fear of blowing something else.
Thanks
Bob
