David0725 wrote:
Hi I am have alot of water coming from the A/c but i dont know why? It never iced up and i could see it drip alittle my guess was condensation we went out for a little while came back ceiling soaking dripping on to the floor and the Dinette. I can't figure out where the water came from. I want on the roof took off the cover it was wer around the compressor and such. But i still cant see how it got in? What sould i.do next?
If it was wet around the compressor and there is no rain, your drain holes are NOT draining the water. Now, IF you are positive the drain holes are clean and have no blockage and you get a LOT of water coming in, the USUAL cause is, the AC Mount bolts are too tight and you have collapsed the AC gasket down so far that the drain holes on the bottom of the pan are touching the roof itself. This is more common with RVP(Coleman) units but you do not specify what brand you have as you can do the same with Dometic units. ALL you have to do is pull the top covers that exposes the evaporator and then pour water onto the Evap drain pan and watch where it goes. IF the water does not flow quickly out of the drain pan thru the 2 side drain holes, then this is probably your problem. Doug
