klm's avatar
klm
loud "thunk" retracting the slide
I have a 02 Newmar. The main slide out made a new and worrisome sound. The clunk, thunk noise seemed to be in the area of the front rail. The slide extended and retracted normally, but I am concerned that there is a problem. The slide is currently extended. I did look at that front rail, nothing looked unusual, but I know nothing about mechanical things. There is a threaded rod, what I can see again looks ok. I cannot see the far end
of either rod or rail. Any ideas?
UPDATE!!!!! The slide has operated normally since that 1 time loud thunk clunk by the front rail. I had the coach serviced at a Newmar facility today. I mentioned the slide issue. Turned out the roller was bad, just that 1, all others good. Replaced with new $17 roller.
Thanks
