Big_steve's avatar
Big_steve
Low mileage issue
I've read many times that low mileage on a Class C is not necessarily a good thing.
What are the issues due to low usage?
What do you consider to be too low mileage on say, a 10 year old MH? Occasionally I see one listed with very low miles like 15K or so.
Also, what would you call high mileage for 10 years?
It's looking like I can afford a MH with 45k to 60k miles, which for a car is pretty young, but I don't know about these big Ford engines. Thoughts on that?
Thanks.
  • the other post are good advice, then there,s a few rv,s sittiing in a garage well cared for ready to go, just gotta go look and check them out.low miles does not scare me ,its where the rv has been sitting for so long and care.
  • Mileage that low on a 10 yr old unit means it probably sat a lot. Either unused or lived in permanently and not moved much. The previous poster is right, seals and hoses dry out. You also have to consider what happens to an unused MH, rodents, bugs, roof, seals, plumbing etc. A mh, just like anything needs to be used and cared for. It's also probable that the genset hasn't been run much either. And not exercising a generator under load at least once a month is the worst thing you can do. All that said, it does not mean it's a bad MH. It may have been meticulously cared for and used sparingly for weekend trips. Those are the variables you need to find out - how it was cared for and used. If it sat, I would look elsewhere unless it's a killer deal and you are prepared to really check it out and possibly bring it back to life. Might be a good find.
  • It's the oil seals and bearings that dry out from non use that can cause problems.
    Hoses, belts and tires can also dry out.
    60 to 80K miles on an engines not the problem at all, if the unit has had regular service done.
    Low miles can be a worse nightmare than high miles.
