A good rough estimate of power loss with altitude is to calculate 3 percent per 1000 feet of elevation gain provided you have a modern engine that adjusts the fuel air mix as required. With engines using a simple carburetor the problem is even worse due to the air fuel mixture being wrong when you change altitude. Going up your mixture gets rich, fouls plugs, might even blow black smoke.
