HBJBIRD's avatar
HBJBIRD
LP GAS DETCTOR
Bought the MTI LP Gas Detector which I read was the direct replacement for the CCI LP Gas Detector which isn't made anymore.
But, The CCI has two red wires, the MTI has one red wire. Do I send back the MTI, or is there a fix for this.
Thank for your thoughts in advance.
  • My memory says that the CCI used two power sources, one from chassis and one from coach. The MTI unit only uses the coach.
    Locate the chassis source pull the fuse, tape off sensor end and that is it.
    If your rig has the solenoid to shut off the propane, you will nedd to change it out.
    Isn't there an 800 number to call? you might be better off there.
