rv_john's avatar
rv_john
LP gas leak detector sounding alert.
Yesterday my LP gas leak detector went on and we had no odor in the rv. I immediately turned off the LP gas tank off and checked for foul smell around stove fridge and even at each air intake and exhaust and around the tank itself but no smell.I turned the detector off then turned it back on and waited and it came on again i turned it off and on again and it stopped buzzing.Next day i opened the LP valve and no more warning until last night again again i shut the valve off and did the same with the detector and of course no more warning. I will be checking all fittings and connections for leaks if no leaks found can someone tell me if these LP detector need replacement or some kind of maintenance if so what is the maintenance. Thanks for your feed back.
Worried RV John.
