2012 Thor Tuscany 42' motorhome. Long story short, the tank level gauge that is screwed into the side of the tank is leaking around the threads when I had the tank filled. I tried to tighten but did n...
Somewhat related. I recently installed a new LP crossover valve. I was told NOT to use Teflon sealing tape on the male inverted flare fittings. But, I smell leaking gas. Should I use sealing steps on those fittings?
