Butch50
Sep 07, 2016Explorer
I would check the pressure as stated above. If that is bad I would suspect the regulator. If the regulator is bad you could be getting a propane smell from it also. If it is the original then it probably went bad.
Also as suggested you could have oil in the line. Oil and propane do get along very well together.
MH tanks do not have the OPD valves in them and they were not around in 1989 time era.
