campmanfromSD's avatar
Oct 23, 2013
lp gas
Just wondering what to do for winterizing????? Do I leave it full or do I run it empty? or 1/2 way????
  • Why are people creating problems? You don't have to do anything with propane in the winter. Think about it, people in cold remote areas use propane to heat with. Just read where some guy thought he had a problem with RV antifreeze in his water heater. So what! Another guy was worried because his tire pressure went up when the tires warmed up, normal. That expansion, due to heat, is allowed for, that's why pressure is read cold.
  • Thanks did all that just wondering if I need to do anything with the propane tank. Thanks
  • On second reading, I see you are asking about the LP system, not the water system. I do nothing for the LP system. It sits like I left it after the last camping trip.
